1 - 4 of 4 Posts
TIA for reading. I have a 2002 SE Wagon withthe DOHC engine. I bought this off somebody 2 years ago for $800 and feel like I have gotten my moneys worth as my DD because the AC is Sooo Cold!
However, I had to replace waterpump a couple of months ago. Back then what I noticed was that once the Serp Belt was removed, the engine idled quietly and consistently. I am now getting the same jerking behaviour, especially at idle even with belt removed. I am also hearing a hissing sound come from the engine at idle. I was going to go ahead and replace valve gasket as it leaks pretty good from there. would a bad valve gasket cause the hissing noise? Im guessing no. So what else would be good to check?
Thanks IA for any advice you may have.
I had a bad valve cover hasket leak that drenched my plugs in oil and cause major misfire and rough idle issue... No more misfire but still idles rough
Sent from my SM-G965U using Tapatalk
same motor ZX5. your top valve DS cover vent to your air box without a valve. Leaky cover gasket get oil ever where!! What vacuum?? look for noise from there. IMHO
I'm having the same problem. We just replaced the valve cover left the gasket on the new one, got from P&P. It was still fully intact. Replaced PCV valve and hose. Idles fine for about 30-60 seconds on cold start but once It gets going starts shaking really bad and we can hear a hissing. Also smells like gas awful bad behind the car. I'm a total clueless idiot when it comes to this stuff but this forum has diagnosed alot for me up untill this point
1 - 4 of 4 Posts
