1 - 3 of 3 Posts
I have a 2000 ZX3 with the MTX75. sometimes when im dricing and come to a stop, when i push the clutch in the revs will rise up and up until i get to a stop. when i finally get to a stop it goes back to idle. it also does it when driving along if i push the clutch in the revs will rise until i hit the next gear and get back on the gas. like i said before it doesnt do this all the time but when it does it gets on my nerves...
any advice or suggestions to what might be causing this would be most appreciated.
nite
does this problem occur shortly after you've started the car?
when my engine is cold it idles at about 1200 rpm until it gets warm. once the engine warms the rpms drop down to like 800 rpm at idle.
i notice when the engine is cold and as i come to a stop and push in the clutch sometimes the rpm's go up.
i thought originally it was because of something catching or sticking because of underhood temps...but it also does this even in cooler weather. and also even after the car is warmed up
1 - 3 of 3 Posts
