The tires are on the 15x6 5 spoke stock rims with no problems.. is it that the rim is .5 wider that will cause problem? The offset on the rims is 42. bad part is i cant afford the right tire now why i was going to use these since there new^^^ he's right, wheels no problem as long as the offset is good. The tires (205/65-15) are around 25.5" that's a little over 1" taller then stock, our cars have small wheel wells and you may have problems. A 205/55-15 would be a great stock height tire to fit.
Good luck.
Well its not just the .5" width increase, its also the 42mm offset.The tires are on the 15x6 5 spoke stock rims with no problems.. is it that the rim is .5 wider that will cause problem? The offset on the rims is 42. bad part is i cant afford the right tire now why i was going to use these since there new
I guess i'll see what happends when i put them on.. i dont think there will be a problem though.. main thing was ebay said the rims wouldn't fit.. im going to be selling my stock 15" double 5 spoke rimsWell its not just the .5" width increase, its also the 42mm offset.
your stock wheels are 15x6 with a 52mm offset,
the new wheels are a 15x6.5 with a 42mm offset.
That will move the entire wheel and tire out 16mm (5/8")as compared to stock, which doesn't sound like much it could be. You should be fine but I would be a little cautious and look for any rubbing while turning, that's all.
