1 - 4 of 4 Posts
The Librarian
Moved to "Wheels, Tires, Brakes & Suspension".
First off... [welcome]
Second off...
I'm assuming you have an SVTF, since this was in SVT Performance Chat.
We'd love to see you car listed in your profile under "What I Drive". [;)]
Stock brakes on your car?
If so, stick with 16" or 17" (stock for SVT).
There's only one or two 15" wheels that will fit over the stock (SVTF) brakes.
Also, if you're buying rims locally, just about every shop will be glad to test fit a rim for you to make sure.
What exactly are you trying to do?
Follow WD40's advise and you won't have any problems. Wheel offset is also important. Try to stick with somthing in the -45 to -49 mm area (49mm being optimum).
1 - 4 of 4 Posts
