1 - 8 of 8 Posts
Motegi Racing
Model: MR116
Exterior: Painted
Manufacturer Part Number: MR11677008740
Sizing and Specifications
Construction: 1 Piece
Rim Diameter: 17 inches
Rim Width: 7 inches
Bolt Pattern (Number of Holes): 4
Bolt Pattern (Pitch Circle Diameter): 100 millimeters
Offset: 40 millimeters
Backspace: 5.57 inches
Item Weight: 20.2 Pounds
Will that fit my focus? right now I have some svt 16 stockers on my 07 and am looking for a change.
two things
Svt wheels are all 17" unless u are talking about SVT contour wheels.
And 40 mm is a bit on the low side. 45-52 is much better if u don't want to rubl
Well I had 18" on mine but oem stock suspension no drop and the clearance was fine. Only time it rubbed is if I hit a drip real hard. So 17"s should make that clearance with out any rubbing, I took mine cause of how much they weighed, I'm currently looking into rota slipstreams
1 - 8 of 8 Posts
