1 - 5 of 5 Posts
· Registered
Did you lube the caliper slides and all the metal to metal contact points? I didn't do this once and had the exact same problem.
Basically you know those bolts the caliper slides on? Pull those out, they typically have a sleeve on them and lube them up. Then lube up all the metal to metal points between the caliper and the plates on the pad themselves so they don't bind in the caliper. Then you should be good to go.
A good lube to use is this stuff.
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=CRC&MfrPartNumber=05359&CategoryCode=3223
Just be sure to do it sooner rather than later. Mine wore down at angles after a week of driving with them like that and ended up needing replacement.
· Registered
mine did this a year ago and wore 3/4's of my rotor off, had it replaced with just used parts and still kinda feels like its doing the same thing and kinda sounds like it to but when i check its all good, so basically i think were having the same problem dude, someone help!! please ha
· Premium Member
simple check for caliper sticking - jack up car, rotate wheel by hand, does it spin freely? then OK! apply brake and try again - if it doesn't spin free, tap the piston sode of the caliper with a soft hammer (rubber, plastic, even a piece of wood), if it spins free now, your caliper is sticking.
These days most calipers just get replaced with rebuilt ones, but they are really easy to clean if you want to save bucks - the problem is usually from corrosion buildup behind th sealing ring causing it to press on the piston constantly preventing normal retraction.
disassembly and cleaning is all that's normally needed (paying special attention to scraping out all the crud in the sealing ring groove) you don't even have to replace the rubber parts unless damaged. this is more common on aluminum calipers such as on motorcycles but it happens to all of them eventually.
1 - 5 of 5 Posts
