1 - 11 of 11 Posts
Backup Lights don't work!
OK where is the sensor for the backup lights? I have checked the fuse and light bulb, must be the shifter sensor. Where is it located, or any suggestions?
From the picture in the 2006 shop manual. Its on the transmission, by the shift linkage. I cannot tell but I think you get to it from underneath the car. Maybe others can clarify on that point.
Under the airbox on the 2000-2004 models, on top of the tranny... maybe the same place on the 05+?
2007 Manual Focus SES Reverse Lights out!
I'm wondering if this sort of thing would be covered under the warranty. I just passed my 30,000 miles and, of course, my reverse lights are not activating when I shift into reverse. Afraid this will affect my State Inspection. The reverse lights come on MAYBE 1 out of 10 times I shift into reverse. Is the fix labor intensive? I haven't performed major maintenance on my car, just a couple oil changes. Is this a sign of a bigger problem?[dunno] [dunno] [dunno]
The basic warranty is 3/36, so if you're under that, you should be covered. In Missouri, reverse lights are not part of a safety inspection.
The reverse switch on the transmission could be your problem, but I'd bet on a wiring issue, like a bad/loose connector. Fix it yourself....probably a difficult job for a beginner.
Any updates on this issue?? I have checked the bulbs, fine, fuses, fine, reverse switch on tranny, replaced. I got nothing. Any thoughts...anyone?
Learn to use a voltmeter, takes maybe 5 minutes. All the good electrical parts on earth mean nothing if there is no power to them.
Avoiding learning something so simple will cost you thousands before it's all over.
Yours and do as you will, just sayin'.
1 - 11 of 11 Posts
