1 - 5 of 5 Posts
hi, i just bought a ford focus zetec 51 plate and just noticed the the reverse light and rear fogs dont work, fuses look fine....any ideas???
also the air con is not working....
thanks
DTC P0606
Check the bulbs. Reverse lights usually fail over time and may not be noticed as they go out. If bulbs are fine, it's likely the reverse switch.
Grounds for the light circuit often fail from corrosion where they connect to the bodywork, but as mentioned - check the bulbs first,,, THEN check for power at the bulb socket - if there is power there THEN check the ground.
Fix all of the above & it'll work again!
I don't know if your English car is a sedan or some /wagon/hatchback...
But if is a wagon/hatchback where there is a unbilicle full of wires
There seems to be lots of problems where wires break,short, open or whatever inside the umbilicle
The sockets for these lamps are known to corrode to pieces, new socket you can buy at a Ford dealer, just remove the sockets & chk them.
1 - 5 of 5 Posts
