sorry bud, If I would have seen this earlier, I would have posted!! The PCV valve is an important part of a car's emissions control system. "PCV" stands for Positive Crankcase Ventilation. The PCV valve takes unburned "blowby" gases - gases that have escaped the combustion chambers by slipping past the pistons into the crankcase - and funnels them back into the intake manifold, where they rejoin the air-fuel mixture and are reburned. The PCV valve recycles these escaped gases, reducing air pollution and preventing moisture buildup inside the engine. The PCV valve is also important for preventative care for your car's engine. Because it prevents moisture buildup inside the engine, the build up of sludge in the oil is also prevented, which will help engine oil to last longer and protects the engine. A PCV valve that needs replacement may cause a rough idle or high hanging revs as a result of pressure buildup within the crankcase.
Any more questions for me??? lol
