1 - 7 of 7 Posts
i was at pull-a-part today getting a valve cover and intake mani off of a '98 contour and i saw that the fuel rail has two fuel lines. if i used this fuel rail could i make a somewhat cheap return fuel system?
also, what are the pro's and con's with a return style?
FF Affiliate
The return lines can be done with your stock Zetec fuel rail , the problems are you need to change the fuel pump and tank , this isnt needed for less then about 330HP
oh ok, what do you think about the valve cover?
have you ever messed with any of those?
FF Affiliate
you have to change to the Contour bolts and gasket but they do fit , its best to find an early NON VCT valvecover so it does not have the big hole at the #1 plug
but if you do find the vavle with the big hole, you just gunna need that plugged up. extra work.
i got the one that has vct. i was thinking that my zetec didnt have that hole. do you know what years have the non-vct zetecs?
Contours from 95-97 are non-VCT. On the return fuel system, its 95-98 & 99 to an extent....some cougar/contiques(contours & mystiques) have return & some returnless in 99.
1 - 7 of 7 Posts
