Hi, great Forum with lots of good reading here. Hope someone can give me advise.
I've read dozens of "vibration and shuddering" problems so here is mine.
While my wife was driving about 200 miles from home, the Focus starting sputtering. It cleared a few times when see pulled over and shut it off. It finally wouldn't clear up and she limped to her destination and called AAA. They towed it to the Ford dealership. The dealership replaced the coil pack, plugs, wires and cleaned the throttle body. $815 whoppin dollars later she drives it home. No more sputttering. But a god awful vibration when it's first started. It's still there when its warmed up, but not as bad.
From what I read, if the car was acclimated to the bad coil pack, or bad wires or plugs, the ECU could think the car is rich/lean when a new coil pack was put on it. Does this make sense? I'll do it ECU reset in the morning, but can anyone think of something else it could be? No CEL codes (I plugged in anyway and ckd), no bad gas mileage. Could the dealership have screwed something up? Or did the wife damage something while the problem was happening? Any thoughts would be appreciated! I'll check the motor mounts also, but it doesn't feel like the problem from the symptoms I've read about in here...
100K on the 2001 Wagon now, and I figure I'll be here often now!
