1 - 8 of 8 Posts
when you reset the computer by disconnecting the battery do you have to have the key in on the "run" position?
i remember something like this for my 5.o stang.
what is the proper procedure?
thanks,
Unhook the negative cable for 15 mins or so. That's it. When you turn the ignition on after that, the trip odo will reset and the head unit will re scan. That's how you know it worked (which it will).
yup, it cleared the trip meter.
thanks to this forum i found a collapsed vac hose that was causing stalling. seems to be running SMOOOOTH now. will take for a spin.
thanks again all.
If you have to do it again remove the positive and negative then hold them together for 10 minutes. Doing that will clear the Keep Alive Memory.
1 - 8 of 8 Posts
