You might as well remove the strut, you'll nearly be there anyway. It is possible to remove the axle without removing the strut, but you'll have to loosen the 3 bolts that hold the strut assembly in place at the top.
You will be separating the ball joint from the knuckle. You will also be removing the sway bar end link from the strut.
A large 3 jaw puller might be needed to separate the axle from the knuckle. I had severe problems loosening mine with a 3lb hammer, and I ended up breaking a puller on the second one. I don't know why that was. It appeared to be a galvanic reaction between the parts IMO, and on the new axle there is anti-seize.
I had an article around here on it, but that was for an MTX, so yours will be different. If you want to take pictures, I'm sure other ATX owners would appreciate reading about your experiences in a How-To.
