Well, I just got done replacing the fuel filter in my daughter's '03 Focus SE, part of our 'fleet' of two, the second an '03 ZTW. This is the first task on this vehicle I have really hated; - WAIT, the brake cables are another juicy story for another time; - they suck too, big time!
Now I know why they charge .6 of an hour to put one of these filter puppies on! I had the shop replace it on my son's '03 ZTW while they did the timing belt, water pump and a few other things related to the belt(s). As an after thought, I threw in a fuel filter and asked them to install it as well.
After struggling with this thing for over an hour, I finally got the clip released that connects the inlet side to the filter. What a pain. No room for your hands, no leverage to release the clip (you can reach around the back of the fitting and almost push the clip out, but not quite. I finally used a 90 degree awl to get under the clip (seems to me it is in backwards, but what do I know!) and pull it out far enough to release it.
There I was, prostrate on the ground, laying in our gravel driveway on cardboard (don't ask why) cursing a blue streak and praying at the same time! Even with the car on a 4 ton axle stand immediately in front of the rear wheel I couldn't get enough room to get under the car to do this with both hands. Of course you need a flashlight because it's darker than ape crap under there, but you also need three hands to do this job too.
Filter was marked MotorCraft and covered in undercoating from the aftermarket coating put on when the car was new. So this tells me it never was replaced in 197,000 Kms.
Why the engineers couldn't have routed the filter on the inside of the frame rail is beyond me. Time for a beer!
