1 - 9 of 9 Posts
Ok, so long story short my antenna base broke. The little thread that you screw the antenna on snapped in half pretty much..........i tried the cheap/easy fix with super glue and that lasted until i opend my door lol.....
So i just ordered the base from cfm and i was just wondering what exactly i'm going to have to do to take the old one out/put the new one on. I haven't really taken a look at it yet but hopefully it isn't too impossible.......as usual, thanks for your help
It's VERY simple man... you take your overhead shroud off and you have like... 2 screws? to remove i believe and then the screw to remove the base... You'll figure it out don't worry. Just don't yank on anything cuz you have your little bulbs wired up there.
Yea like nov173 said, all you do is take that plastic piece off and it will expose the two screws you need to undo. Piece of pie.
what they said...i had to replace mine a while back and it was real simple
Flat Black King
yea what they said. i had to replace mine to cause i broke the antenna off trying to wash the car. figured it out by reading on here and fixed it.
what are you doing with it? replacing or removing?
1 - 9 of 9 Posts
