1 - 5 of 5 Posts
my used 2000 focus had a beat up a/c bezel.. the numbers and hot/cold were all scratched off so i got a another one from these forums.. they are in transmit and i wanted to know how difficult it is to pry off the plastic cover and get to the a/c bezels... are there just tabs holding hte black dash in place?
any tips?
thanks!!!
Jetsetter
1. Remove stereo
Insert DIN removal tools into holes on deck
Pull radio out
Unplug antenna wire and all wiring harnesses
2. Remove 4 x 7mm hex screws from the corners of the stereo opening
3. Remove ashtray and cigarette lighter
4. Pull bezel from stereo opening, popping the two top clips, then bottom
5. Unscrew Hazard button LED (2 screws)
6. Unplug cigarette lighter
7. Unscrew HVAC control (4 screws)
8. Unscrew Defrost buttons (3 screws) (not necessarily in this order)
what is the din removal tool for? where can i get one? is it required to rmeove the plastic panel to get to the ac bezels?
1 - 5 of 5 Posts
