1 - 4 of 4 Posts
Please somebody tell me how to change the darn License Plate bulbs. I can't figure out how to get them out without tearing something up. 2000 ZX3.
Thanks.
If you have your Owner's Manual, check it, it should have instructions. The manual for the 2005 model sez:
"Replacing license plate lamp bulbs
1. Make sure the headlamp control
is in the OFF position.
2. Insert a flathead screwdriver in
the recess and pry out the complete
light assembly.
3. Pull the bulb straight out."
I do not know if the 200 model was the same.
It is an easy yet tricky thing to do. Insert a flathead screwdriver in the recess on the right and then push the lens to the left until you feel you can pry it out. Follow the same exact directions for both lights.
1 - 4 of 4 Posts
