1 - 4 of 4 Posts
About two days ago, I replaced the alternator on my 2002 SVT Focus and this morning, my car straight died, stalled as I was driving it, the electrical systems and lights started flashing etc. I had to get it towed.
Upon further inspection, I found that the battery had died and the positive battery charging cable that connected to the alt had melted. Straight melted. Other than that, 100% appeared to be no issue. I'm going to have to take the alt back and exchange it because I had to break off the stud to get the damned ground wire loose.
I plan on going back, testing all of the wires to make sure that they are not faulty themselves, replacing the alt with a new one, replacing the battery and seeing how that goes. My buddy told me that he believes the battery might have been [:)][:)][:)][:)][:)][:)]g the alternator or that there may be a short somewhere in the charging cable keeping the alt from charging the battery. It drove about 50-60 miles just beautifully and then this.
Any advice would be very much appreciated.
2004 Focus Wagon, Zetec DOHC, Auto
Sounds like you had a short occur somewhere in the alternator-to-battery wire. Maybe it rubbed up against something and wore through the insulation. You should be able to find that fairly easy by examining the cable.
Charge the battery using a charger...don't use the alternator to charge a dead battery...and then have it load tested at a parts store to verify that it is still good.
Vince your Moderator
The thicker wire that goes to the stud on the Alt is NOT a ground. It is the Battery positive that goes to the starter and then to the positive side of the battery.
It sounds like you grounded the alt.
Pics always help
A loose connection can do it. A bad battery can do it. A scraped up wire can do it. All you can do is replace the cable to the battery, and possibly the negative battery cable + terminal since that one is giving you problems removing the terminal. Have the alternator tested, and replace the battery. I have serious doubts that the battery is any good now, but you can try having it charged again.
1 - 4 of 4 Posts
