So after doing some research here, I came to the conclusion that my Transmission's "A" solenoid was faulty. Car runs great, but when shifting from 2nd to 3rd gear problems are present. If you leadfoot the pedal, the engine revs up, then the trans shifts into 3rd gear but a click noise is heard. If you normally press the accelerator, the transmission will shift smoothly, but it slips sometimes. Any suggestions or tips on this issue? I would hate to spend a lot of money on replacing the transmission unless there is another solution that I could try.
