1 - 5 of 5 Posts
Lurking
could any one tell me how hard it is to change the axle on the right side? i have a oem from ford.... i just saw today the boot on the CV joint has busted and globed out all over the place :p so if any one could help me with this...
Its fairly simple.....
Jack it up
pull off the wheel
disconnect the strut from front knuckle (this allows you more movement... and its only 1 bolt)
take off bracket on back side of skirt (keeps the axel in place)
push axel in toward tranny while moving front hub outwards.. this should allow the axel to come loose... keeping the axel level should help it come out easier.
Thats pretty much it... I'm sure someone will jump in if I've missed anything.
Good to know, I'm replacing both here soon, they've developed a little bit of play.
1 - 5 of 5 Posts
