1 - 6 of 6 Posts
Mine has an ugly pinstripe down each side. How can I go about removing these without leaving a mark? I was thinking heat them up then peel them off but don't want a mark left behind. Any ideas?
Pin stripe wont leave a mark unless your car has alot of fade in the paint, then there will be a mark but otherwise the adhesive in pinstripe inst strong enough to be an issue, use a hair dryer or go out and do it on a hot day and you should be fine. Welcome! I see your in NC, check out the dragon run we are doing the 29th-2nd.
Nick
A hair dryer, finger nails and some patience usually works wonders. After that, remove any sticker residue with Goo Gone and then follow with some wax.
1 - 6 of 6 Posts
