1 - 2 of 2 Posts
hey everyone,
I recently bought a 2003 focus and i am very happy that it is in a great condition - everything looks brand new.
however, i discovered that there used to be a sticker on the top of my rear view window of wich you can still see the outlines. i saw this when i was driving back home at night and the windows were fogged up because it was very cold outside.
if the window is dry, you can't see it, but as soon as it gets wet (when its fogged up or when washing it) you can clearly read the letters of the removed sticker.
i have tried cleaning the spot with alcohol such as acetone, but unfortunately this did not have any effect whatsoever.
do any of you have a good tip for me? have you had a similar issue, and if yes, what did you do to solve the problem?
thanks in advance! [thumb]
FF Cleaning Squad
Get some adhesive remover and a razor, also a trick I like to use is get a large eraser and rub where the sticker was and then clean off the eraser residue.
Hope it helps.
1 - 2 of 2 Posts
