1 - 8 of 8 Posts
Stock
I need to remove the front foam to mount my intercooler and I was wondering how to get the foam off and still be able to reuse it once I have the intercooler mounted.
Thanks.
It just pulls off. You may have to take the bumper off, but I would think you'd have to have it off to istall the ic anyway. But it just has a tiny bit of glue on it.
once u take it off, i breaks the peiceo n teh back of the foam. but you still can use it, jsut make a strap out of zippy ties and throw it back on.
Take off the bumper and it will most likely just pop right off, if the car was buit on a good day it probally has one bead of glue down the center. If it was built on a bad day two globs of glue on each end. you should put it back on when you're done because it keeps the bumper from shaking and makin a ton of noise at high speed
[drinking] [hatchet]
Stock
Discussion Starter · #7 ·
Hmm well i dont see any glue holding it on, instead there are two large rivets holding it...I think im just gonna cut some of the foam to mount my ic. I dont feel like drilling them out and then installing new...at least for now.
yea just do that, but definitely leave it on there as it helps so you dont trash your bumper if you accidentally bump into something.
1 - 8 of 8 Posts
