1 - 5 of 5 Posts
Hi guys,
I searched a lot and didn't find anything for the SVT, just regular zx3. Please help!!! I am trying to see if it possible to recharge the frion(?) with R-134A on the SVTF or whether you have to have a mechanic do that. I couldn't find the correct valve to refill/check pressure. Is it under the car just like zx3? Has anyone done this? Thanks everyone (again :) !!!
Mods, please move this to the correct forum if it's in the wrong place.
Edit: I found this on focushacks. Is this guide for SVTF? Thanks...
http://www.focushacks.com/index.php?modid=85&ht=Air Conditioner re-fill and service
Low Pressure should be in the same spot on the SVT as the Zx3 Under the passenger side wheel
High Pressure should be In front of the battery
Refill the car on the low side port.
Shake Can Apply the Gauge / Can.
Turn the car on full A/C
Check Gauge Fill as needed while car is running and a/c is on.
Here is a thread sticky
http://focusfanatics.com/forum/showthread.php?t=195638
If you run your a/c and the Clutch keeps clicking on and off that means your car is low on Freon or Completely empty which could damage the compressor DO NOT RUN THE A/C Without filling her up.
Goodluck.
1 - 5 of 5 Posts
