1 - 2 of 2 Posts
OK peeps....how do I detach the rear window wiper on a 2015 SE Hatchback?
It won't move 90 degrees to the rear window so I can get a good look at things and I don't want to bust something. There must be some clips that squeeze in? squeeze out?
I had thought of just removing the wiper arm but would rather not do that in case it introduces some, as yet, unknown issue.
Thanks
Discussion Starter #2
OK I'm going back outside to try this approach.
I should have looked on You Tube first but it is quite flattering for the site that I logged in here first without thinking of You Tube.
errr no link for some reason, anyway it shows a Ford Edge replacement, same wiper arm.
1 - 2 of 2 Posts
