1 - 6 of 6 Posts
I need to replace this part.
Anyone know what its called? cause I certainly don't. It looks like I can just unbolt the bad one and put in a new one that I pulled from a junk yard or bought from ford.
It's called a trailing arm. It may have many different names depending on who you talk to though.
Deutsche Arsche
What the hell did yo do to bend that? Did yo cut th eABS cable as well? Make sure it is for an SVT just in case it is different, I think only the LCA is different though. Oull the oart number off of it for cross reference.
Would the part number be on it? and cut both ABS wiring and hydraulic brake line. I already fixed both of those so this is the only repair left. and LCA? I don't know anything about cars other than what I've had to learn to keep mine running.
LCA=lower control arm
1 - 6 of 6 Posts
