1 - 12 of 12 Posts
Good Day, this is my first post onto this site, I have been haveing a problem with the rear tire wear on my car 2000 se, I had some work done to the car in the past 6 months i had new rear suspension put in along with the two control arms on both side replace due to the car swaying badly going over bumps. now im on my second set of tires and they are wearing alot faster than they should be and i almost need to replace them again anyone have any simular problems or have any idea of what could be causeing this to happen.. Any help would be great thanks.
Adam
Welcome to FF! Did you have the car alignmened? Also is the wear across the whole tire, or either edge of the tire?
Yeah i had an Alignment done after i got the work done to it cause i thought it couldnt hurt and might need it, the wear seems to be the whole tire.
The plaCE THAT DID YOUR ALIGNMENT SHOULD BE WILLING TO CHECK IT FOR FREE OR A NOMINAL CHARGE... Sorry, stupid caps lock button.
toe is if your tire is is straight and not draging at an angle
good tow is like this =
bad tow is like this >
that is if you were looking straight down over the car.
hope i explained it good enough.
Adam
Tell us what your aligment specs are.
Shot me 3 deer!!!
did u get softer tires?
I went throw 5 sets first set rear out of line cupped out tires the rest to soft plus high speed last set is holding up i got them off the inter-net their called runways.
1 - 12 of 12 Posts
