So I keep reading about all the trouble people have replacing their rear shocks and springs on 2000 - 2004 Focus, usually resulting in replaced rear lower arms after much pain and suffering.
I am no stranger to this, I had this issue on my first 2003 SVT when I upgraded the entire suspension.
I have another 2003 SVT now, and started the same upgrade, forgetting how much of a pain it was the first time. Started off on the passenger side, trying to get the lower bolt out. Same deal. Lots of heat, some WD40, and a long bar only resulted in broken sockets (2 of them). I started looking at the drivers side. That wheel/tire were still on, and on the ground (Had the passenger side rear corner jacked up with a jack stand on it.).
So I decide to start fooling with that side. I never took the wheel/tire off. In 5 minutes I had the shock completely out - I took the bottom shock bolt out, and the top nut under the carpet. Threw the new one in, no sweat. Then, I pulled the camber adjustment bolt out of the crossmember, and disconnected the sway bar on both sides and pivoted that out of the way. The control arm easily went low enough to get the old spring out, and the new on in place. Grabbed my floor jack and pushed the arm back up, and reinstalled the camber bolt.
Can it be this EASY? Literally, 20 minutes for the shock and the spring, no blood sweat or tears, and I didn't even have to remove the wheel. I must be missing something, is there a reason NOT to do it this way?
