First off new to Focus Fanatics, so I apologies if this has already been addressed. I've owned my focus for about 17 months now and have done some minor upgrades such as, Eibach Sportline Springs/Pro-Dampers, cross and drilled rotors front and back, K&N drop in filter, and audio. I've also replaced clutch/flywheel, motor mounts and transmission mounts, shifting cables, alternator, etc.
My question has to do with my slight scrapping on bumps or when the rear is weighed down, at first I thought I may need to roll my fenders seeing how I'm running 225's but I discovered now that my tires are actually making contact with the rear splash guard bolts. Should I just remove the entire rear splash guards or will just trimming down the bolts fix this issue?
