My son just bought a 2002 Focus and the driver side rear light wont turn on when other lights are on. It works when Hazards are on.. Brake light on the same side works. I changed the bulb, problem remains....
Check the wiring harness through the hatch or wagon gate. They made the wires just a bit too short and they tend to split and fray.
Peel back the black rubber boot and you'll likely find a few insulation breaks. Electrical tape fixes it fine if the wire is intact. If not, splice in a piece, solder, heat shrink, and you're good to go.
I've allready checked that, everything is ok for that part, but can the actual connector be opened ?? I see a clip on one side but cant seem to open it....
I've a problem with the socket before, mine was the reverse light. Did my best to clean the contacts, and slid a bulb in and out quite a few times, and that worked.
Working with a dual element bulb, the flasher/brake light portion working just proves that side "hot" & the ground are OK - "hot" to the running light side could still be bad anywhere.
Test light to start tracing back looking for power on the running light circuit might help.
Related Threads
Focus Fanatics Forum
5.8M posts
189.4K members
Since 2003
