1 - 7 of 7 Posts
Check the wiring harness through the hatch or wagon gate. They made the wires just a bit too short and they tend to split and fray.
Peel back the black rubber boot and you'll likely find a few insulation breaks. Electrical tape fixes it fine if the wire is intact. If not, splice in a piece, solder, heat shrink, and you're good to go.
That would be my first guess.
Working with a dual element bulb, the flasher/brake light portion working just proves that side "hot" & the ground are OK - "hot" to the running light side could still be bad anywhere.
Test light to start tracing back looking for power on the running light circuit might help.
1 - 7 of 7 Posts
