Its easy. Use a flathead. Pop off your power window switch. Unplug it and set it aside. Remove the trim piece up top and the trim piece for the door pull. Also will need small flathead to remove trim piece from behind your door handle on the inside. Then use a torx bit to remove the couple torx bits that are there. And a few screws are on the very bottom of the door panel and one on the side. That should be all that holds it on.
