1 - 2 of 2 Posts
Ok, this may be a little hard to explain, but my rear drivers side door is having some issues. Basically what it is doing is if you open from the inside, its fine, works perfectly everytime, but the outside, if the car is locked, and you unlock it, it will not open from the outside, however, if you unlock it, open it from the inside, and then shut it, it will open just fine from the outside. So its like the lock will only unlock the inside, until the door has been opened. Any suggestions?
Detailing Freak
sounds like it could be a connecting rod inside the door, for the outer handle... ive never taken a focus door apart, yet...yet.... but either one of the rods inside popped off, or the handle is messed up somehow
1 - 2 of 2 Posts
