1 - 6 of 6 Posts
yes i read the how to but im still nervous to try it...anyone local to me willing to help(who has done it or knows how to) for some beers or lunch let me know...I should have them by the weekend...just ordered them..jamie
You should try the regional forums. This really isn't a difficult install though.
The key is to have a jack under the lower control arm when you both remove and replace the bolt. It will allow you to raise and lower the suspension to get the bolt out and back in. Start with the arrow pointed striaght up. Helps the alignment tech if you also paint the arrow on the bolt head as well (much easier to see).
is that the bolt that holds the springs together if so mine is so rusted im afraid of taking it out?
thanks ill check the regional fourms
1 - 6 of 6 Posts
