I misplaced my shop manual, so I'm hoping someone can help.
I need to remove the rear bumper cover off an SVT. I removed the nuts from the studs hiding behind the splash guards, and removed all the plastic push pins on top and underneath (I think).
When we spread the sides to clear the studs away from the body, the cover still seems to be hanging up on something. Are there any more studs/bolts hiding somewhere? Is there a special procedure for removing it... up and out, or swing the bottom, or top when you pull?
Thanks.
Thanks.
