ok everyone i'm new to the forum i don't really use my car for anything other than daily driver, I started using cherokeeforum when i got my jeep and it's been a pretty good tool. i figured it may prove handy for the problem i'm having with my focus.
so I did the spark plugs on it, and the valve cover gasket. few weeks went y then it started to idle rough and it threw the check engine light at me, a couple days later it would idle really bad and even shut off on me when i wasnt revving it..
SYMPTOMS: ROUGH IDLE AND A HISSING NOISE.
CODES: P0171 SYSTEMM TOO LEAN BANK 1
P0351 IGNITION COIL A PRIMARY/SECONDARY CIRCUIT FAULT
P0352 COIL B (SAME EXACT CODE AS ABOVE)
P0400 EGR FLOW FAULT
P2195 SENSOR EXCESS LEAN SIGNAL BANK 1 - SENSOR 1
i replaced the 2 ignition coils (the ones closest to the front of the engine) and it would still die as SOON as i let off the throttle (wouldn't hold an idle on it's own) .. so i put the 2 new coils on the last 2 cylinders and the car idles rough but it doesn't shut off anymore which is a big improvement considering it wouldn't even stay on without some gas.
i'm thinking the lean bank 1 code and the 02 sensor b1 are from the misfire that's happening and the egr might be plugged up or worn out.
should i replace the 2 coils that i haven't yet replaced? can it be the spark plugs, they're new look fine, no oil not even burnt and don't smell like gas, and it isn't a misfire code that the car is giving me.
i appreciate any and all help, thanks!
