Have a Zetec with mild mods, cat back, SVT intake, tune. 180 deg stat, ambient temps are -5 to +10 deg C. Have had the car for approx 20,000 km so have no idea of service history other than clearly the basic maintenance was done well and I've fixed the rest of it up quite well since owning it. While data logging I've noticed that my knock sensor is retarding the timing up to 7 deg under light loads (typical of normal to moderate acccel).
I've removed the tune, and noted that the pids behave the same. Inspection of knock sensor reveals nothing out of the ordinary, connections good, etc. Pulled plugs to check for carbon buildup, no boroscope but tops of pistons are clean. Had a coworker (Ford tech) recommend running a tank of 94 with a bottle of octane booster to see if the knock changes or stops at all so I ran the tank empty and filled up with higher oct and booster but have seen no change. There's no knock if I put some load on it stone cold but as soon as it starts to warn up at all the KS lights up. No CEL, no codes.
Tom has sent me a different tune to send him data log of which I intend to do once I get my tank back to 91 octance. I'm just interested in getting a discussion going to see what others have experienced with this.
What have you guys experienced and what do you think about real vs false knock?
