I finally got time to fix the refresh button my my focus and i found a few things. First the actuator that opens the door to let fresh air in does work, but it rotates 360 degrees while the door only rotates 90 degrees, which is probably what made the door to strip and now just the actuator rotates freely. I managed to take the door out and flip it since the other side has a hole and imanaged the fit the actuator into it. I pressed the button, but the actuator still rotates 360 degrees which is causing the hole to get stripped again.
Can somebody confirm that the actuator keeps rotating or working after the door closes or opens? I have never seen an actuator that kept working after it closed or opened the vent. And also does anybody have a part# for the door itself? For an 03 lx
Thanks
Thanks
