Random VCT Question
1181 8
What are the benefits or removing vct from the svt? Not planning on doing it just looking for new knowledge.
1 - 9 of 9 Posts
http://www.focusfanatics.com/forum/showthread.php?t=45532
post #1
'With what i have seen installing a VCT Elim there was a 5 to 6 HP/TQ loss at 1000 2,3.4.5.6.7000 Rpms..............
Old post I realize, but at that time you DID say there was a loss of power..............you no longer believe that? I realize also that just WHERE one puts the now locked cam timing with no VCT would have plenty to do with any possible outcome and thusly any comparison there. You make no mention of timing numbers and DOHC cams can be splayed to add to BOTH ends of the spectrum.
If the VCT has no power effect through timing changes then how can dyno tuned degreed-to-perfection cams increase power???
The crux of the matter, if truly no power gained then lock the cam timing at EGR best effect and see what happens, Ford could save millions. It doesn't take a whole lot of thought there to figure out why they haven't done it.
I disagree with the statement of no power added. The mere fact of VCT switching the timing says there is. No need to switch timings back and forth if that is true.
a priori
FF Affiliate
A tune and more playing with the adj cam gears on the dyno showed no loss over all when all the testing was done and why its a must to dyno tune cam gears
Just like the ZX2 the SVT VCT is there for emissions not performance
When you install adj cam gears there is no pins in the cams so 90% of the time your going to have them off a little and a adj cam off a little can be a hugh loss of HP and TQ and why you have to dyno tune adj cam gears
Not arguing that at all, why I threw this in there............
'DOHC cams can be splayed to add to BOTH ends of the spectrum.'
You doing what you do and knowing pretty much the trick numbers I could easily see the '5 or 6' being made up to be even or even more. My statement was more of an either-or without the custom dyno tuning in there.............
1 - 9 of 9 Posts
