So a few months ago my wife drove the focus up to ohio and it started to have issuses...She pulled off at a pep boys and they told her the valve cover gasket failed and fouled the plugs....400 dollars later and a never fixing the problem....(car got towed home).....i fixed it later.....
I just decided to to run some seafoam and swap out the plugs since i found a box in the trunk, but the plugs i removed were autolite dbl platinum....i decided to check the gap on them and i noticed that one was about .035 and the rest .065...i understand that there is a little carbon on them but that far apart? are autolite dbl platinum not supposed to be gapped?
[offtopic] also found out they broke a valve cover bolt head off....so at least i can say they removed the valve cover.....
