1 - 6 of 6 Posts
I've got a pin hole on the motor side of the radiator. About two inches from the top towards the passenger side. I've used Barr's /Bards stop leak to some success in past cars that I didn't care about. Is there any reason one shouldn't use it again? I'd rather not buy a new radiator if not needed. But I don't want to adversely affect anything else. The leak is sooo small. In the right lighting and at the right angle you can see it misting out.
It may work, hard to say. That said, I wouldn't use it myself even on my older vehicles. Looks like aftermarket radiators are about $70 - $85. No other issues with the cooling system that would be causing the leak?
No I'm pretty sure I hit it with something when I was in there. I didn't realize I actually punctured it until yesterday. I noticed the oil temps were getting high but the engine temp guage was where it normally is. I looked and I was low on coolant. I filled it up and found the tiny amount of spray. I didn't realize radiators were that cheap. That being the case I'll just do it right and get a new one. It's not a pressing issue as the leak is so small it would take a week or two till I would have to top it off. Thanks
Not a problem, the prices I saw were for online stores. I'm sure autoparts stores around you will have them in stock, could be slightly more expensive but nothing outrageous.
[facepalm]
No.
Leak.
Stop.
Never! (unless it is an emergency)
Funny thing is that for many cars, you can buy a new radiator for about the same that a radiator shop would charge to repair yours. While you're at it, replace hoses, thermostat, gaskets, yadda yadda.
1 - 6 of 6 Posts
