Hey guys, got 2006 Ford Focus 2.0 L. Recently got backed into and the troubles started. After a few weeks, got the check engine light cleared after a piece of fuzz on MAF(it was giving a lean code).
It has since been acting up, though I don't have a check engine light on. I decided just to replace MAF since that was the initial culprit. I have also changed fuel filter and replaced spark plugs. The new problem is that it has a lack of power. It drives fine, however going down the interstate at 75 it needs to drop down a gear to climb even the smallest incline, where it usually was able to hold speed without gearing down. I don't know where I should look next, I can't seem to hear what could be a leak, I've also tried carb cleaner to try and locate vacuum leak. What could be my problem? Would I still be able to drive it as much as a do if the fuel pump was going bad?
