svt
in thirty three years of road racing this is my 1st fwd, thou not my smallest. that was the vee. lots of adjustments. no trail braking, for instance. that said, having stiffened up the rear end a lot, the car rotates beautifully. if you are familiar w/summit, i use 3rd gear in turns 1 and 5, catch 4th in 2 and carry it until 5 w/a little brake for 3. i catch 4th again between 6 and 7 and carry it all the way to about pit out (a little brake for 10 to settle the car) where i catch 5th. on a good day we run about 1:33s. trap speed on front straight about 118 at end. w/the r-4 porterfield we dont have to brake until past 2nd to last marker on straight. the little bugger has suprised some much faster cars in the twisties there. the svtf is in its element on track. btw, the tire pressures i found work well there in temperate weather is this. cold-lf=22, lr-25, rf=23, rr=26. when fully warm that brings them to 33 lbs.all around. the reason for one lb less on left is that the higher speed turns stress that side and they generate more heat. oh also they need at least two degrees neg camber in front.
