1 - 5 of 5 Posts
Allright. My current setup is a ZX3 with an Eibach Sportline lowering springs. Drops 2.5 inches or so. The current wheels and tires are 18 inch wrapped in 215/35/18. That rubs when I hit major dips or the like and is causing problems. My NEW setup will be EAP Dark Argents at 17 inches wrapped in 205/45/17. Since I dropped down an entire inch and only gained maybe 10 millimeters, is this going to rub still!?[???:)]
Any help is GREATLY appreciated!
My 17's almost never rub unless I'm really loaded... Also, you can look under the car and see where it rubs, and sometimes trim the material, I had to roll my rear fenders just at the top.
I never had an issue with the rears, my rear tires were MINT. But the fronts took some damage. I figure it wouldnt harm since Im taking off an inch or so.
Discussion Starter · #5 ·
Your not livin till your livin low my friend! [headbang]
1 - 5 of 5 Posts
