So I downloaded the instructions on how to change the manual crank window to power windows and everything looks fine... however I'm just replacing the existing regulator with a new one (the *superstrong* white plastic part that connects glass/rail/steelcables broke). So my problems arose when I tried to disconnect the glass from this white plastic part. How do you do it? There's a cylindrical white plastic connector that appears to be pressure-fitted, however due to the limited visibility I can't tell how to remove it safely (since the new window regulator assembly does not come with this cylindrical connector) I assume that I need to remove this part and recycle it... no? I don't want to have to break out my drill and.... Please help! FYI I know I'm a newbie and I've searched already the forum.... [
