1 - 6 of 6 Posts
Stock
Ok i bought my kit used and I need to know what size an fitting do I need to tap the block? Its the only fitting mine didnt come with.
Stock
Oops that would help to know right. Sorry, its the psi side, the kit came with a oil pan already tapped so I dont need that fitting cause it was included.
FF Affiliate
I get the oil supply from the fitting behind the coil pack , It is a 1/8 NPT to a -3an (the AN wouldnt depend on your size line tho ) you will have to trim the coil pack bracket but it still leaves you 2 bolts to bolt it on and works well there
Make sure you get a T or something so you can run your oil psi gauge and the oil feed line. This is assuming yr oil psi gauge is mechanical, use copper tubing as the nylon tends to break over time.
1 - 6 of 6 Posts
