1 - 9 of 9 Posts
I been looking on the site about doing a svt rear brake swap besides the obvious pads,disk, calipers and lines . The only thing missing is the rear spindle and hub?
slow
e-brake cables
R.I.P Kona
Nope. Also don't forget about the caliper mounting bracket which you will have to get used since Ford has stopped making them.
w/ my magic bag
FRPP's #M-2300-SVTR
Just order FRPP's #M-2300-SVTR from Steve @ Toulsey Ford or CFM & get it coming. All new part's!
R.I.P Kona
Steve will yell you he can no longer supply the rears because of no caliper brackets.
^^looks like I wont be going with either of those The CFM aren't available till January
Discussion Starter #8
Will the rear brakes over power the stock front brakes? If so Could I just swap to a svt front rotor?
w/ my magic bag
Baer brake's
For the front you will need FRPP's #M-2300-SVTF4, to work on your car= SVT rotor's/ caliper's/ hub's/ spindle's. To upgrade your front brake's your going to need SVT spindle's & that opens the door for any BBK. I'm using PbR caliper's, which is the '94-'04 Cobra caliper's & 13'' rotor's. Baer Brake's #1001426. Upgraded from SVT brake's,
1 - 9 of 9 Posts
