1 - 3 of 3 Posts
hey guys im getting the frpp full kit for my 07 zx3 now my question is will i need the cam bolts for the rear and the plates for the front because i got my 07 stang to align out perfect with the drop springs which were steeda sports with nmo mods other then the springs any info and i will be doing the alignment my self so any personal experience with the alignment is appreciated
Unlikely you'll need camber adjustment for the front as camber is tolerated a little better up front. You may need it for the rear. We dropped our focus 1.5" with and Eibach Pro kit. The pre-drop rear camber on our 03 was -1.6 degrees (the way it came from the factory and every car is going to differ) and it increased to -1.9 degrees as a result of the drop. This, in my opinion is too much even with minimum amounts of rear toe-in. We used the rear camber bolts and easily got it down to -1.4 degrees. Even a little less is OK especially if you're an aggressive stop and go driver.
sounds good thanks for the info
1 - 3 of 3 Posts
