I saved the wallpaper with no problem. I wanted to rid myself of the Ford power up and power down logo. Balls....figures you can't change that one.do you mean the logo that shows up on power up and power down for the ford background for MFT? all you do for that is go to options, wallpaper, and then there should be a list of them you find the picture you want and you save it as the wallpaper
the ford power up power down screen cannot be changed
Probably, but I would wager there is no way to implement such a change without a copy of the original operating system image, emulator software that reads the image and a computer and some kind of interface to load it all back on the car.Can you create a new file and give it the same name as the ford logo file? In the past I have been able to do that with mandatory image files.
File name of logo doesn't show. More then likely the logo is built-in the IPL (Initial Program Load) of the software and therefore you cannot change.Can you create a new file and give it the same name as the ford logo file? In the past I have been able to do that with mandatory image files.
