I'm going to try my best to explain this and see if i can get some advice. I have the DCT and when i come to a complete stop the RPM's drop all the way down to 500rpm, luggs for a brief second (because of the low RPM) and then jumps back up to the idle RPM which i have set at 900rpm right now. It seems to me like it is staying in gear all the way until it hits 500rpm then it goes into neutral causing it to go back up to the 900rpm idle.
Is this normal?
It's kind of anoying, i'd rather it go into neutral at after it gets under the idle rpm that i have set at 900rpm as of right now, rather then waiting until it gets to 500rpm before popping into neutral. the lug it does drives me crazy.
I never noticed it before but i also just recently installed the FSwerks rear motor mount insert. So i'm not sure if i'm just noticing it now because i can feel the transmission better with a stiffer mount.
Is this normal?
